integrity check before delete
Hello,
What are the best practices in Joget for doing an integrity check with a delete.
Example:
- I have an object form and a color form.
- an object has a color and a color can correspond to n object.
- if I remove a color without checking, I will have an inconsistency in my object list.
Is it possible to check before deleting a color that it is not related to objects.
      Thank you.
      I will follow these ideas.
        Hi, if you need to enforce additional data integrity, you can manually add constraints in your database tables. Alternatively, perhaps you could create a specific deletion process (with appropriate flow logic) or deletion form (with the appropriate Form Validator) in place.
