Hi, is that the complete stacktrace showing the actual root cause? The message "Can't allocate Id for object table" seems to indicate that the database could have some kind of corrupted data.
Hi Joget Expert, Can someone share what is the error below? How can the error below happened?
ERROR 07 Apr 2021 11:13:19 DatabaseManager - SyncDBTransaction.afterCompletion rollback failed 12385407
java.sql.SQLException: INTERNAL ERROR: unexpected DataObjectException
at com.lutris.appserver.server.sql.standard.StandardDBTransaction.rollback(StandardDBTransaction.java:473)
at org.enhydra.dods.jta.SyncDBTransactionFactory$SyncDBTransaction.afterCompletion(SyncDBTransactionFactory.java:158)
at bitronix.tm.BitronixTransaction.fireAfterCompletionEvent(BitronixTransaction.java:549)
at bitronix.tm.BitronixTransaction.rollback(BitronixTransaction.java:336)
at bitronix.tm.BitronixTransaction.commit(BitronixTransaction.java:264)
at bitronix.tm.BitronixTransactionManager.commit(BitronixTransactionManager.java:143)
at org.enhydra.shark.utilities.dods.DODSUtilities.updateCaches(DODSUtilities.java:157)
at org.enhydra.shark.utilities.dods.DODSUtilities.getNext(DODSUtilities.java:98)
at org.enhydra.shark.instancepersistence.DODSPersistentManager.getNextDecId(DODSPersistentManager.java:4450)
at org.enhydra.shark.instancepersistence.DODSPersistentManager.persistVariablesBLOB(DODSPersistentManager.java:1031)
at org.enhydra.shark.instancepersistence.DODSPersistentManager.persist(DODSPersistentManager.java:989)
at org.enhydra.shark.WfActivityImpl.persistActivityContext(WfActivityImpl.java:1991)
at org.enhydra.shark.WfActivityImpl.activate(WfActivityImpl.java:236)
at org.enhydra.shark.WfProcessImpl.startActivity(WfProcessImpl.java:918)
at org.enhydra.shark.WfProcessImpl.queueNext(WfProcessImpl.java:1134)
at org.enhydra.shark.WfProcessImpl.run(WfProcessImpl.java:750)
at org.enhydra.shark.WfProcessImpl.activity_complete(WfProcessImpl.java:969)
at org.enhydra.shark.WfActivityImpl.finish(WfActivityImpl.java:441)
at org.enhydra.shark.WfActivityImpl.complete(WfActivityImpl.java:366)
at org.enhydra.shark.WfActivityWrapper.complete(WfActivityWrapper.java:230)
at org.joget.workflow.model.service.WorkflowManagerImpl.assignmentComplete(WorkflowManagerImpl.java:4239)
at org.joget.workflow.model.service.WorkflowManagerImpl.assignmentComplete(WorkflowManagerImpl.java:4262)
at sun.reflect.GeneratedMethodAccessor703.invoke(Unknown Source)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:282)
at org.joget.apps.app.service.AuditTrailInterceptor.invoke(AuditTrailInterceptor.java:17)
at org.joget.apps.app.service.SqlFilterAspect.invoke(SqlFilterAspect.java:36)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
at com.sun.proxy.$Proxy52.assignmentComplete(Unknown Source)
at org.joget.apps.app.service.AppServiceImpl.completeAssignmentForm(AppServiceImpl.java:403)
at sun.reflect.GeneratedMethodAccessor701.invoke(Unknown Source)
at com.sun.proxy.$Proxy87.completeAssignmentForm(Unknown Source)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm_aroundBody80(InboxMenu.java:470)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm_aroundBody81$advice(InboxMenu.java:45)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm_aroundBody82(InboxMenu.java:1)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm_aroundBody83$advice(InboxMenu.java:95)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm(InboxMenu.java:1)
at org.joget.apps.userview.lib.InboxMenu.submitForm_aroundBody76(InboxMenu.java:398)
at org.joget.apps.userview.lib.InboxMenu.submitForm_aroundBody77$advice(InboxMenu.java:45)
at org.joget.apps.userview.lib.InboxMenu.submitForm_aroundBody78(InboxMenu.java:1)
at org.joget.apps.userview.lib.InboxMenu.submitForm_aroundBody79$advice(InboxMenu.java:95)
at org.joget.apps.userview.lib.InboxMenu.submitForm(InboxMenu.java:1)
at org.joget.apps.userview.lib.InboxMenu.handleForm_aroundBody64(InboxMenu.java:302)
at org.joget.apps.userview.lib.InboxMenu.handleForm_aroundBody65$advice(InboxMenu.java:45)
at org.joget.apps.userview.lib.InboxMenu.handleForm_aroundBody66(InboxMenu.java:1)
at org.joget.apps.userview.lib.InboxMenu.handleForm_aroundBody67$advice(InboxMenu.java:95)
at org.joget.apps.userview.lib.InboxMenu.handleForm(InboxMenu.java:1)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage_aroundBody40(DataListInboxMenu.java:156)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage_aroundBody41$advice(DataListInboxMenu.java:45)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage_aroundBody42(DataListInboxMenu.java:1)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage_aroundBody43$advice(DataListInboxMenu.java:95)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage(DataListInboxMenu.java:1)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody24(UserviewMenu.java:132)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody25$advice(UserviewMenu.java:45)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody26(UserviewMenu.java:1)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody27$advice(UserviewMenu.java:95)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage(UserviewMenu.java:1)
at org.joget.apps.userview.service.UserviewUtil.getUserviewMenuHtml(UserviewUtil.java:94)
at org.apache.jsp.WEB_002dINF.jsp.ubuilder.view_jsp._jspService(view_jsp.java:636)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:443)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:385)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:329)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:728)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:467)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:392)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:311)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:168)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:304)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1286)
at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1041)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:984)
at org.joget.commons.util.AnalyzerFilter.doFilter_aroundBody0(AnalyzerFilter.java:17)
at org.joget.commons.util.AnalyzerFilter$AjcClosure1.run(AnalyzerFilter.java:1)
at org.aspectj.runtime.reflect.JoinPointImpl.proceed(JoinPointImpl.java:149)
at org.joget.commons.util.AnalyzerAspect.analyzeRequests(AnalyzerAspect.java:54)
at org.joget.commons.util.AnalyzerFilter.doFilter(AnalyzerFilter.java:17)
at org.owasp.csrfguard.CsrfGuardFilter.doFilter(CsrfGuardFilter.java:59)
at org.joget.apps.app.web.ExpireFilter.doFilter(ExpireFilter.java:44)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.ha.tcp.ReplicationValve.invoke(ReplicationValve.java:322)
at org.apache.catalina.ha.session.JvmRouteBinderValve.invoke(JvmRouteBinderValve.java:193)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
ERROR 07 Apr 2021 11:13:21 Persistence - Persisting of ActivityVariable failed
ERROR 07 Apr 2021 11:13:21 org.joget.workflow.model.service.WorkflowManagerImpl - org.enhydra.shark.api.internal.instancepersistence.PersistenceException: Persisting of ActivityVariable failed
java.lang.Exception: Can't allocate Id for object table _activitydata_
at org.enhydra.shark.utilities.dods.DODSUtilities.updateCaches(DODSUtilities.java:176)
org.enhydra.shark.api.internal.instancepersistence.PersistenceException: Couldn't allocate id
at org.enhydra.shark.instancepersistence.DODSPersistentManager.getNextDecId(DODSPersistentManager.java:4452)
Caused by: java.lang.Exception: Can't allocate Id for object table _activitydata_
... 171 more
at org.enhydra.shark.instancepersistence.DODSPersistentManager.persistVariablesBLOB(DODSPersistentManager.java:1110)
Caused by: org.enhydra.shark.api.internal.instancepersistence.PersistenceException: Couldn't allocate id
... 170 more
... 171 more
