You can get the SQL queries to 'clean' the SHK tables fromĀ Development Server Data Cleaning#3.DeletecompletedprocessinstancesdatatocleanupmoreXPDLsfromcache. Do backup your database before making any major DB changes.
If I have 1000 process id to be deleted , Is it possible to delete it together (if I delete from shkProcesses) or I should delete each process from monitor
