How to synchronize using of another workflow variable using beanShell
I have 2 workflow (Main and voting )
when the main workflow generate voting processes
Main contains 2 workflow variables:
voteYes - number of processes(voting workflow) that votes yes
voteNo - number of processes(voting workflow) that votes no
voted - number of voted users
In voting activity
there is only one activity that user vote yer/no then a tool that increment the voted variable and increment voteYes if he choose yes
code:
String count = workflowManager.getProcessVariable(mainProcessId, variableName);
int countInt;
countInt = Integer.parseInt(count) + 1;
count = Integer.toString(countInt);
workflowManager.processVariable(mainProcessId, variableName, count);
the problem:
No synchronization , If 5 users vote together the main variables will not be correct
Is there a way to add OS metaphor, Semaphor or Mutex
      Hi, you may want to change your app design to capture each individual user vote. In this case, then you can easily perform a sum or any other analysis on the votes as required.
