Go to Application Performance Management and click on records that contain error count (right most). Then correspond with the timestamp you have in the server log to match the error. This way, you can find out which page is throwing the error.
Hi, may I know how to trace for this error code in my systems log?
How is the code implemented and in which tool (a tool, or a load, etc)?
Not sure, is there anyway I can check which code trigger this error?
