In Grid > Options > Value, you are declaring the column ID. Make sure that all the IDs matches the FormRow.put("ID","value") in your code.
- Rahul Katara
Thanks Bastiana, It did work :)
Try to inspect this block of code. Put a System.out.println() in the while loop to check. Maybe there's no data returned at all.
while (grs.next()) { FormRow gr1 = new FormRow(); gr1.put("gridColumn1", grs.getString(1)); gr1.put("gridColumn2", grs.getString(2)); gr1.put("gridColumn3", grs.getString(3)); gr1.put("gridColumn4", grs.getString(4)); gr1.put("gridColumn5", grs.getString(5)); fgrid.add(gr1); }
- Rahul Katara
Hi, I have tested the code using the print statement and the sql query is returning values for all the five fields used in my query: I want to populate them these five fields in my grid as follows: Do I need to add any code for populating the headers? Name Date Role Actions Notes andy Jun 19, 2015 4:32:01 PM Support Analyst Send for IM Approval clark Jun 22, 2015 2:49:40 PM Integration Manager Form Assigned
I have 2 forms:
Form1 - aas_routes - Parent Form - Saving Route information
Form2 - routes_notes - Child Form - Saving every action performed on the above form
In my scenario, I am using a Grid in the parent form to populate the "Route_notes" data to show the actions/audit notes performed on the parent form by different Users in each activity of the Workflow.
I am using the following Bean Shell Code:
import java.sql.Connection;
import java.sql.ResultSet;
import java.text.DecimalFormat;
import javax.sql.DataSource;
import java.sql.*;
import org.apache.commons.collections.SequencedHashMap;
import java.util.*;
public FormRowSet getgridData() {
FormRowSet fgrid = new FormRowSet();
fgrid.setMultiRow(true);
try {
con = ds.getConnection();
if(!con.isClosed()){
String routeId = "#form.aas_routes.id#";
String sql = "Select c_name,datecreated,c_Role,c_status,c_notes from APP_FD_ROUTE_NOTE where c_request_id1='"+routeId+"' order by datecreated ASC";
PreparedStatement stmt = con.prepareStatement(sql);
ResultSet grs = stmt.executeQuery();
fgrid.add(gr1);
} catch(Exception ex) {
System.err.println("Exception: " + ex.getMessage());
} finally {
try {
if(con != null) con.close();
} catch(SQLException e) {}
return fgrid;
return getgridData();
I have selected following the Grid to be shown as mentioned below:
I am not getting any error in the Logs. However, I do not see any value being populated in the Grid from the database table.
Could you please let me know where I am getting wrong in my configuration?
