Hi, the error says "query size is >= to max_allowed_packet". You will need to configure your MySQL database server like in https://stackoverflow.com/questions/8062496/how-to-change-max-allowed-packet-size.
- ayohmang
hi Anders, max_allowed_packet has been increased to 500MB, the problem still exist. we're using mysql 5.5. Is it possible to upgrade to latest MariaDB supported by Joget. What is the most stable Mysql/MariaDB suited with Joget ? We're using Joget Enterprise v6.0.32.
Hi, this exception recently appeared in joget logs and causing memory leak ( below < 1gb free memory). What are actually causing this problem ? (joget v6 ent 6.0.32). is there any data missing in process assignment ?
ERROR 27 Aug 2021 10:11:04 org.joget.apps.app.service.AuditTrailManagerImpl - Error executing audit trail plugin org.joget.plugin.enterprise.FormDataAuditTrailPlugin
org.hibernate.exception.GenericJDBCException: could not execute statement
at org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:54)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:126)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:112)
at org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:211)
at org.hibernate.engine.jdbc.batch.internal.NonBatchingBatch.addToBatch(NonBatchingBatch.java:62)
at org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:3124)
at org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:3581)
at org.hibernate.action.internal.EntityInsertAction.execute(EntityInsertAction.java:104)
at org.hibernate.engine.spi.ActionQueue.executeActions(ActionQueue.java:465)
at org.hibernate.engine.spi.ActionQueue.executeActions(ActionQueue.java:351)
at org.hibernate.event.internal.AbstractFlushingEventListener.performExecutions(AbstractFlushingEventListener.java:350)
at org.hibernate.event.internal.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:56)
at org.hibernate.internal.SessionImpl.flush(SessionImpl.java:1258)
at org.joget.commons.spring.model.AbstractSpringDao.save(AbstractSpringDao.java:29)
at org.joget.apps.form.dao.FormDataAuditTrailDaoImpl.addAuditTrail(FormDataAuditTrailDaoImpl.java:12)
at sun.reflect.GeneratedMethodAccessor352.invoke(Unknown Source)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:283)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
at com.sun.proxy.$Proxy47.addAuditTrail(Unknown Source)
at org.joget.plugin.enterprise.FormDataAuditTrailPlugin.storeSaveAuditTrail_aroundBody20(FormDataAuditTrailPlugin.java:118)
at org.joget.plugin.enterprise.FormDataAuditTrailPlugin$AjcClosure21.run(FormDataAuditTrailPlugin.java:1)
at org.springframework.transaction.aspectj.AbstractTransactionAspect.ajc$around$org_springframework_transaction_aspectj_AbstractTransactionAspect$1$2a73e96cproceed(AbstractTransactionAspect.aj:66)
at org.springframework.transaction.aspectj.AbstractTransactionAspect$AbstractTransactionAspect$1.proceedWithInvocation(AbstractTransactionAspect.aj:72)
at org.springframework.transaction.aspectj.AbstractTransactionAspect.ajc$around$org_springframework_transaction_aspectj_AbstractTransactionAspect$1$2a73e96c(AbstractTransactionAspect.aj:70)
at org.joget.plugin.enterprise.FormDataAuditTrailPlugin.storeSaveAuditTrail_aroundBody22(FormDataAuditTrailPlugin.java:106)
at org.joget.plugin.enterprise.FormDataAuditTrailPlugin.storeSaveAuditTrail_aroundBody23$advice(FormDataAuditTrailPlugin.java:95)
at org.joget.plugin.enterprise.FormDataAuditTrailPlugin.storeSaveAuditTrail(FormDataAuditTrailPlugin.java:1)
at org.joget.plugin.enterprise.FormDataAuditTrailPlugin.execute_aroundBody12(FormDataAuditTrailPlugin.java:59)
at org.joget.plugin.enterprise.FormDataAuditTrailPlugin.execute_aroundBody13$advice(FormDataAuditTrailPlugin.java:95)
at org.joget.plugin.enterprise.FormDataAuditTrailPlugin.execute(FormDataAuditTrailPlugin.java:1)
at org.joget.apps.app.service.AuditTrailManagerImpl.executePlugin(AuditTrailManagerImpl.java:178)
at org.joget.apps.app.service.AuditTrailManagerImpl.addAuditTrail(AuditTrailManagerImpl.java:102)
at org.joget.apps.app.service.AppWorkflowHelper.addAuditTrail(AppWorkflowHelper.java:592)
at org.joget.workflow.util.WorkflowUtil.addAuditTrail(WorkflowUtil.java:339)
at org.joget.apps.app.service.AuditTrailInterceptor.invoke(AuditTrailInterceptor.java:27)
at com.sun.proxy.$Proxy32.saveOrUpdate(Unknown Source)
at org.joget.apps.app.service.AppServiceImpl.storeFormData(AppServiceImpl.java:1585)
at org.joget.apps.app.service.AppServiceImpl.storeFormData(AppServiceImpl.java:1504)
at sun.reflect.GeneratedMethodAccessor537.invoke(Unknown Source)
at com.sun.proxy.$Proxy57.storeFormData(Unknown Source)
at org.joget.apps.form.lib.DefaultFormBinder.store_aroundBody16(DefaultFormBinder.java:99)
at org.joget.apps.form.lib.DefaultFormBinder.store_aroundBody17$advice(DefaultFormBinder.java:95)
at org.joget.apps.form.lib.DefaultFormBinder.store(DefaultFormBinder.java:1)
at org.joget.apps.form.lib.WorkflowFormBinder.store_aroundBody14(WorkflowFormBinder.java:97)
at org.joget.apps.form.lib.WorkflowFormBinder.store_aroundBody15$advice(WorkflowFormBinder.java:95)
at org.joget.apps.form.lib.WorkflowFormBinder.store(WorkflowFormBinder.java:1)
at org.joget.apps.form.service.FormServiceImpl.recursiveExecuteFormStoreBinders(FormServiceImpl.java:528)
at org.joget.apps.form.service.FormServiceImpl.recursiveExecuteFormStoreBinders(FormServiceImpl.java:518)
at org.joget.apps.form.service.FormServiceImpl.executeFormStoreBinders(FormServiceImpl.java:498)
at org.joget.apps.form.service.FormServiceImpl.submitForm_aroundBody0(FormServiceImpl.java:287)
at org.joget.apps.form.service.FormServiceImpl$AjcClosure1.run(FormServiceImpl.java:1)
at org.joget.apps.form.service.FormServiceImpl.submitForm(FormServiceImpl.java:261)
at sun.reflect.GeneratedMethodAccessor608.invoke(Unknown Source)
at com.sun.proxy.$Proxy30.submitForm(Unknown Source)
at org.joget.apps.app.service.AppServiceImpl.submitForm(AppServiceImpl.java:1372)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at com.sun.proxy.$Proxy57.submitForm(Unknown Source)
at org.joget.apps.form.lib.SaveAsDraftButton.actionPerformed_aroundBody6(SaveAsDraftButton.java:34)
at org.joget.apps.form.lib.SaveAsDraftButton.actionPerformed_aroundBody7$advice(SaveAsDraftButton.java:95)
at org.joget.apps.form.lib.SaveAsDraftButton.actionPerformed(SaveAsDraftButton.java:1)
at org.joget.apps.form.service.FormUtil.executeActions(FormUtil.java:660)
at org.joget.apps.form.service.FormUtil.executeActions(FormUtil.java:668)
at org.joget.apps.form.service.FormServiceImpl.executeFormActions(FormServiceImpl.java:445)
at sun.reflect.GeneratedMethodAccessor560.invoke(Unknown Source)
at com.sun.proxy.$Proxy30.executeFormActions(Unknown Source)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm_aroundBody40(InboxMenu.java:457)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm_aroundBody41$advice(InboxMenu.java:95)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm(InboxMenu.java:1)
at org.joget.apps.userview.lib.InboxMenu.submitForm_aroundBody38(InboxMenu.java:398)
at org.joget.apps.userview.lib.InboxMenu.submitForm_aroundBody39$advice(InboxMenu.java:95)
at org.joget.apps.userview.lib.InboxMenu.submitForm(InboxMenu.java:1)
at org.joget.apps.userview.lib.InboxMenu.handleForm_aroundBody32(InboxMenu.java:302)
at org.joget.apps.userview.lib.InboxMenu.handleForm_aroundBody33$advice(InboxMenu.java:95)
at org.joget.apps.userview.lib.InboxMenu.handleForm(InboxMenu.java:1)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage_aroundBody20(DataListInboxMenu.java:156)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage_aroundBody21$advice(DataListInboxMenu.java:95)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage(DataListInboxMenu.java:1)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody12(UserviewMenu.java:132)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody13$advice(UserviewMenu.java:95)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage(UserviewMenu.java:1)
at org.joget.apps.userview.service.UserviewUtil.getUserviewMenuHtml(UserviewUtil.java:94)
at org.joget.apps.userview.service.UserviewThemeProcesser.getContent(UserviewThemeProcesser.java:599)
at org.joget.apps.userview.service.UserviewThemeProcesser.getHtml(UserviewThemeProcesser.java:168)
at sun.reflect.GeneratedMethodAccessor349.invoke(Unknown Source)
at javax.el.BeanELResolver.getValue(BeanELResolver.java:94)
at org.apache.jasper.el.JasperELResolver.getValue(JasperELResolver.java:113)
at org.apache.el.parser.AstValue.getValue(AstValue.java:169)
at org.apache.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:190)
at org.apache.jasper.el.JspValueExpression.getValue(JspValueExpression.java:115)
at org.apache.jsp.WEB_002dINF.jsp.ubuilder.v5view_jsp._jspx_meth_c_005fset_005f0(v5view_jsp.java:250)
at org.apache.jsp.WEB_002dINF.jsp.ubuilder.v5view_jsp._jspx_meth_c_005fif_005f0(v5view_jsp.java:207)
at org.apache.jsp.WEB_002dINF.jsp.ubuilder.v5view_jsp._jspService(v5view_jsp.java:158)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:71)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:466)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:382)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:330)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:711)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:460)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:387)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:315)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:168)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:304)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1286)
at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1041)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:984)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:652)
at org.joget.commons.util.AnalyzerFilter.doFilter_aroundBody0(AnalyzerFilter.java:17)
at org.joget.commons.util.AnalyzerFilter$AjcClosure1.run(AnalyzerFilter.java:1)
at org.aspectj.runtime.reflect.JoinPointImpl.proceed(JoinPointImpl.java:149)
at org.joget.commons.util.AnalyzerAspect.analyzeRequests(AnalyzerAspect.java:54)
at org.joget.commons.util.AnalyzerFilter.doFilter(AnalyzerFilter.java:17)
at org.owasp.csrfguard.CsrfGuardFilter.doFilter(CsrfGuardFilter.java:59)
at org.joget.apps.app.web.ExpireFilter.doFilter(ExpireFilter.java:44)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:201)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:544)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:364)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:616)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1629)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.sql.SQLException: (conn=3422) Could not send query: query size is >= to max_allowed_packet (268435456)
at org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.get(ExceptionMapper.java:262)
at org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.getException(ExceptionMapper.java:164)
at org.mariadb.jdbc.MariaDbStatement.executeExceptionEpilogue_aroundBody2(MariaDbStatement.java:244)
at org.mariadb.jdbc.MariaDbStatement.executeExceptionEpilogue_aroundBody3$advice(MariaDbStatement.java:123)
at org.mariadb.jdbc.MariaDbStatement.executeExceptionEpilogue(MariaDbStatement.java:1)
at org.mariadb.jdbc.ClientSidePreparedStatement.executeInternal_aroundBody6(ClientSidePreparedStatement.java:225)
at org.mariadb.jdbc.ClientSidePreparedStatement.executeInternal_aroundBody7$advice(ClientSidePreparedStatement.java:123)
at org.mariadb.jdbc.ClientSidePreparedStatement.executeInternal(ClientSidePreparedStatement.java:1)
at org.mariadb.jdbc.ClientSidePreparedStatement.execute_aroundBody0(ClientSidePreparedStatement.java:145)
at org.mariadb.jdbc.ClientSidePreparedStatement.execute_aroundBody1$advice(ClientSidePreparedStatement.java:123)
at org.mariadb.jdbc.ClientSidePreparedStatement.execute(ClientSidePreparedStatement.java:1)
at org.mariadb.jdbc.ClientSidePreparedStatement.executeUpdate_aroundBody4(ClientSidePreparedStatement.java:176)
at org.mariadb.jdbc.ClientSidePreparedStatement.executeUpdate_aroundBody5$advice(ClientSidePreparedStatement.java:123)
at org.mariadb.jdbc.ClientSidePreparedStatement.executeUpdate(ClientSidePreparedStatement.java:1)
at org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:208)
... 245 more
Caused by: java.sql.SQLTransientConnectionException: Could not send query: query size is >= to max_allowed_packet (268435456)
at org.mariadb.jdbc.internal.protocol.AbstractQueryProtocol.handleIoException(AbstractQueryProtocol.java:1935)
at org.mariadb.jdbc.internal.protocol.AbstractQueryProtocol.executeQuery(AbstractQueryProtocol.java:245)
at org.mariadb.jdbc.ClientSidePreparedStatement.executeInternal_aroundBody6(ClientSidePreparedStatement.java:216)
... 254 more
