Redirect me to setup link!!
When I try to reach localhost:8080/jw
it redirect me to http://localhost:8080/jw/setup
I tried to restart joget and computer same result when I started the joget
  1. Camilo A. García
    Have you installed mysql or mariadb servers independently? It is possible that you have a DB instance already running and it is occupying the port that the instance that is integrated into Joget is trying to occupy?
    On the other hand, could it be a windows firewall permission problem (it may be blocking the port, for example)?
  2. Issa
    There is no application running on port 3307(port of mariadb server)
    I will check if it is firewall permission issue
    Read Custom Database Configuration for more information.
    1. Issa
      how I can start database,
      I tried to mariadb-start then start joget but same result
      this is the error:
      java.sql.SQLNonTransientConnectionException: Could not connect to address=(host=localhost)(port=3307)(type=master) : Socket fail to connect to host:localhost, port:3307. Connection refused: connect
      at org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.get(ExceptionMapper.java:241)
      at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.connectWithoutProxy(AbstractConnectProtocol.java:1241)
      at org.mariadb.jdbc.internal.util.Utils.retrieveProxy(Utils.java:610)
      at org.mariadb.jdbc.MariaDbConnection.newConnection(MariaDbConnection.java:142)
      at org.mariadb.jdbc.Driver.connect_aroundBody0(Driver.java:86)
      at org.mariadb.jdbc.Driver.connect_aroundBody1$advice(Driver.java:155)
      at org.mariadb.jdbc.Driver.connect(Driver.java:1)
      at com.mysql.jdbc.Driver.connect_aroundBody0(Driver.java:29)
      at com.mysql.jdbc.Driver.connect_aroundBody1$advice(Driver.java:155)
      at com.mysql.jdbc.Driver.connect(Driver.java:1)
      at org.apache.tomcat.jdbc.pool.PooledConnection.connectUsingDriver(PooledConnection.java:310)
      at org.apache.tomcat.jdbc.pool.PooledConnection.connect(PooledConnection.java:203)
      at org.apache.tomcat.jdbc.pool.ConnectionPool.createConnection(ConnectionPool.java:718)
      at org.apache.tomcat.jdbc.pool.ConnectionPool.borrowConnection(ConnectionPool.java:650)
      at org.apache.tomcat.jdbc.pool.ConnectionPool.init(ConnectionPool.java:468)
      at org.apache.tomcat.jdbc.pool.ConnectionPool.<init>(ConnectionPool.java:143)
      at org.apache.tomcat.jdbc.pool.DataSourceProxy.pCreatePool(DataSourceProxy.java:118)
      at org.apache.tomcat.jdbc.pool.DataSourceProxy.createPool(DataSourceProxy.java:107)
      at org.apache.tomcat.jdbc.pool.DataSourceProxy.getConnection(DataSourceProxy.java:131)
      at org.apache.tomcat.jdbc.pool.DataSource.getConnection(DataSource.java)
      at org.apache.tomcat.jdbc.pool.XADataSource.getConnection(XADataSource.java)
      at org.joget.commons.util.DynamicDataSource.getConnection_aroundBody0(DynamicDataSource.java:48)
      at org.joget.commons.util.DynamicDataSource$AjcClosure1.run(DynamicDataSource.java:1)
      at org.aspectj.runtime.reflect.JoinPointImpl.proceed(JoinPointImpl.java:149)
      at org.joget.commons.util.AnalyzerAspect.analyzeDbcpOpenConnections(AnalyzerAspect.java:170)
      at org.joget.commons.util.DynamicDataSource.getConnection(DynamicDataSource.java:20)
      at org.hibernate.engine.jdbc.connections.internal.DatasourceConnectionProviderImpl.getConnection(DatasourceConnectionProviderImpl.java:139)
      at org.hibernate.engine.jdbc.internal.JdbcServicesImpl$ConnectionProviderJdbcConnectionAccess.obtainConnection(JdbcServicesImpl.java:279)
      at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.configure(JdbcServicesImpl.java:124)
      at org.hibernate.boot.registry.internal.StandardServiceRegistryImpl.configureService(StandardServiceRegistryImpl.java:111)
      at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:234)
      at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:206)
      at org.hibernate.cfg.Configuration.buildTypeRegistrations(Configuration.java:1887)
      at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1845)
      at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1930)
      at org.springframework.orm.hibernate4.LocalSessionFactoryBuilder.buildSessionFactory(LocalSessionFactoryBuilder.java:372)
      at org.springframework.orm.hibernate4.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:454)
      at org.springframework.orm.hibernate4.LocalSessionFactoryBean.afterPropertiesSet(LocalSessionFactoryBean.java:439)
      at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1689)
      at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1627)
      at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
      at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:481)
      at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:312)
      at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
      at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:308)
      at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
      at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
      at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
      at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1534)
      at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1281)
      at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:551)
      at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:202)
      at org.springframework.context.support.AbstractApplicationContext.initMessageSource(AbstractApplicationContext.java:713)
      at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:531)
      at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:443)
      at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:325)
      at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
      at org.joget.commons.spring.web.CustomContextLoaderListener.contextInitialized(CustomContextLoaderListener.java:31)
      at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4770)
      at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5236)
      at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
      at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:754)
      at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:730)
      at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:744)
      at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:980)
      at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1851)
      at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
      at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
      at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
      at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
      at java.base/java.lang.Thread.run(Thread.java:834)
      Caused by: java.sql.SQLNonTransientConnectionException: Socket fail to connect to host:localhost, port:3307. Connection refused: connect
      at org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.connException(ExceptionMapper.java:87)
      at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.createSocket(AbstractConnectProtocol.java:218)
      at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.createConnection(AbstractConnectProtocol.java:474)
      at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.connectWithoutProxy(AbstractConnectProtocol.java:1236)
      ... 83 more
      Caused by: java.net.ConnectException: Connection refused: connect
      at java.base/java.net.PlainSocketImpl.waitForConnect(Native Method)
      at java.base/java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:107)
      at java.base/java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:399)
      at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:242)
      at java.base/java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:224)
      at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:403)
      at java.base/java.net.Socket.connect(Socket.java:591)
      at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.createSocket(AbstractConnectProtocol.java:213)
      ... 85 more
    Joget will redirect to http://localhost:8080/jw/setup if it cannot access or connect to the database. Check to ensure your database is up and running.
    1. Issa
      this is the error:
      ... 83 more
      ... 85 more
