Hi, when using a platform like Joget, the frontend UI is already visual drag and drop, and in most cases you only need minor CSS and JavaScript to customize the UI. JQuery is only mainly used to help manipulate the DOM, so you could even just use vanilla modern JavaScript to do it. You could develop your own themes using Vue or Angular or React, but personally I don't see much point in doing it.
Hi, @Lim Yi Zheng @Hugo @Anders @Matthew King @Camilo A. García
Why doesn't joget use vue or angular or react?
The jquery technology is very old and is now almost eliminated.
