[Workflow] Method to Export/Import on DX/7?
Hey Everyone,
The Apps and Datalist Import/Export works like a charm... but workflows aren't clear to me. I don't mind using JSON copy/paste... but I have not found a method in the wiki's.
Thanks!
      On the top right of "process builder", click debug, you will get the definition of the process design.
      You can save that file, for safekeeping.
      To import it back in, go to "debug", paste it and submit.
        Thanks Bastiana!
        I was able to find that debug, with the pop-out. I did NOT test it, but see how the "update" would work as an import/export feature.
        To go WAY under the hood/in the backend: do you know if this is the same in the respective "package.xpdl" file that's within a Project's /<Joget Src Path>/wflow/app_src/<APP>/<App Version>/ folder?
