Start Process from Datalist Hyperlink Action
From this reference: Start Process from Datalist Hyperlink Action,
I found some issue if there's multiple value stored in database if using element such as check box, list selection and multiple select box.
For example value stored in field select1 = 'teams;zoom', select2 = 'wfh;wfo', select3 = 'glove;mask'
url once hyperlink is click:  /jw/web/userview/test/test/_/editFormfke_select1=zoom%3Bteams&fke_select2=wfh%3Bwfo&fk_select3=glove%3Bmask
there's no value displayed in either check box, list selection or multiple select box. But if using text field, value is displayed correctly.
This is from Joget DX version. Not sure about other versions. Is this supposed to be normal or a bug?
      Hi Anas Misbah Shami,
      Here is the setting in hyperlink for all 3 fields:
      JSON for form:
      "className": "org.joget.apps.form.model.Form",
      "properties": {
      "loadBinder": {
      "className": "org.joget.apps.form.lib.WorkflowFormBinder"
      "name": "Test Multi Value",
      "description": "",
      "id": "testMultiValue",
      "storeBinder": {
      "tableName": "sendEmail"
      "elements": [
      "elements": [
      "elements": [
      "className": "org.joget.ListSelectionElement",
      "properties": {
      "controlField": "",
      "readonly": "",
      "optionsBinder": {
      "className": "",
      "properties": {}
      "options": [
      "label": "zoom",
      "value": "zoom",
      "grouping": ""
      "label": "teams",
      "value": "teams",
      "grouping": ""
      "validator": {
      "className": "",
      "properties": {}
      "workflowVariable": "",
      "id": "select1",
      "label": "Select 1",
      "value": "",
      "readonlyLabel": ""
      "className": "org.joget.apps.form.lib.TextField",
      "properties": {
      "maxlength": "",
      "validator": {
      "className": "",
      "properties": {}
      "label": "Text Field Select 1",
      "encryption": "",
      "size": "",
      "readonly": "",
      "style": "",
      "id": "select1",
      "placeholder": "",
      "value": "",
      "readonlyLabel": "",
      "storeNumeric": ""
      "className": "org.joget.apps.form.lib.CheckBox",
      "properties": {
      "controlField": "",
      "readonly": "",
      "optionsBinder": {
      "className": "",
      "properties": {}
      "options": [
      "label": "wfh",
      "value": "wfh",
      "grouping": ""
      "label": "wfo",
      "value": "wfo",
      "grouping": ""
      "validator": {
      "className": "",
      "properties": {}
      "id": "select2",
      "label": "Select 2",
      "value": "",
      "readonlyLabel": ""
      "properties": {
      "maxlength": "",
      "validator": {
      "className": "",
      "properties": {}
      "label": "Text Field Select 2",
      "encryption": "",
      "size": "",
      "readonly": "",
      "style": "",
      "id": "select2",
      "placeholder": "",
      "value": "",
      "storeNumeric": ""
      "className": "org.joget.plugin.enterprise.MultiSelectBox",
      "properties": {
      "controlField": "",
      "readonly": "",
      "optionsBinder": {
      "className": "",
      "properties": {}
      "options": [
      "label": "glove",
      "value": "glove",
      "grouping": ""
      "label": "mask",
      "value": "mask",
      "grouping": ""
      "multiple": "true",
      "width": "40%",
      "validator": {
      "className": "",
      "properties": {}
      "id": "select3",
      "label": "Select 3",
      "value": "",
      "readonlyLabel": ""
      "properties": {
      "maxlength": "",
      "validator": {
      "className": "",
      "properties": {}
      "label": "Text Field Select 3",
      "encryption": "",
      "size": "",
      "readonly": "",
      "style": "",
      "id": "select3",
      "placeholder": "",
      "value": "",
      "storeNumeric": ""
      "className": "org.joget.apps.form.model.Column",
      "properties": {
      "width": "100%"
      "className": "org.joget.apps.form.model.Section",
      "properties": {
      "label": "Section",
      "id": "section1"
        Please send a screen of the configurations of all three fields on the form from where you are submitting the data and where you are trying to get it
