Deleting texts in Spreadsheet on mobile devices V 6
Hello team.
I am using a spreadsheet in a form to quickly capture some values in tabular format. Sometimes I even pre-fill the text fields so that only what is necessary is edited. On a laptop it works perfectly.
BUT, when the same is done in a mobile device when one of the cells is clicked, it does not allow us to edit the value, but rather it clears the field and does not allow us to do the editing. Have you seen this behavior? Is it possible to avoid it and make it behave the same as on the pc by editing the pre-filled value?
Regards!
  1. Bastiana
    Can you elaborate on how do you "pre-fill the text fields"?
    I think this has been fixed earlier, do download and install the latest Joget DX 7.0.25 version.
