cloud on-demand plugin config
Hi - we are looking to leverage the joget-dx on-demand platform as we grow. we are using a plugin that require a file in the server (aws upload plugin required the aws3.properties to be configured). would this be a limitation of the system? meaning not having a way to upload the file to the app install folder?
      Hi, I believe it depends on which plan you intend to use. I would assume that it is possible if you have a dedicated plan, I suggest that you make a direct inquiry to clarify.
