files in wflow directory not found
greetings - I installed the latest docker image from docker hub. everything seems to work, but I get an error when I try to reference a file installed in the wflow directory (it is a redirect of the local file system of course)....
ERROR 28 Apr 2022 01:33:30 org.joget.AwsS3FileBinder - java.io.FileNotFoundException: /opt/joget/wflowawsS3.properties (No such file or directory)
seems that there is a missing '/ ' between the wflow and the filename. is this is a setting in the new docker images?
      See Working docker-compose.yml file it might help if you put the wflow folder outside of the docker instance. then you can maintain state of the file data too.
        Hi - yes it is the AWS Plugin.  the instructions are to  simply create that file in the  wflow  directory and it typically works. I have two other installs with no isssues, so that is why I thought its the new install.
        are there other ways to store attachments to AWS or other platforms?
          It seems that you are using a AWS plugin?
            Hi, I'm not sure whether there has been any change in the Docker image, but how is that file being referenced? Why not just add the missing slash?
