Hi, it depends on your competency and the level of customization required. For many cases, you might not even need to do any coding at all. For simple customizations, you can just use HTML, CSS and JavaScript. For more complex requirements, you can use Java to take advantage of BeanShell scripting. If you intend to build plugins, then you would need to be competent in Java, there are guides and examples in Developing Plugins.
Which are the Languages(Specific topics) we have to learn for Joget? Because if we want to write Some conditions or modifications, we can't do.
