Hi Zakir,
I suggest you study the Employee Services Portal, Purchase Requisition and Internal Service Requisition app. It will give you a good foundation to decide on how you can start to develop your app.
Regarding GUI, Joget has existing Userview themes (Userview Theme) that you can customize using CSS/JavaScript. Or alternatively you can develop your own custom GUI (refer to Userview Theme Plugin).
Cheers,
Jack
Hello guys,
If we use joget workflow, we can create of kind application with complete workflow and report (with i report). you can create application with drag & drop to form and table will be auto generate into joget. You can build application with fast and flexible. thanks.
Hi, I am looking to move our existing business retail system to a web based solution.
I cam across Joget and its workflow engine and would like to introduce workflow system into the new web system. The web system will be created from scratch.
1) WIl Joget be able to create a web portal for my system, from data processing to reporting.
Front End GUI interface: Can this be customized as per our needs or we have to stick with the Joget Framework
2) Can I integrate the workflow engine into our existing tables or do I have to use the tables created by Joget.
Basically I want o know how well will and existing system design integrate with Joget from the database side.
We already have tables to handle eg Purchase Req , Purchase Orders etc
thanks
Zakir
