get textbox value with another table?
Dear all master,
How to get value in textbox with another table in form joget..
thank you.
      thanks for answer, how is sample, i can will be submit form and when insert data will be value use formula insert function, and this textbox value get from other table.. how can this case. thank you.
        Hi there!
        You could use a load binder on the form or the section to set the value in the TextField or you could put the value you want in some Workflow Variable and use a hash variable to populate the Workflow variable's value in the TextField.
        Hope this helps.
        Thanks!
