Hi, perhaps you can try the answer from Using the JSON API to create a new form record with file column?
- A. Chaudhary
Thank you, Anders. It works.
I want to update File Upload filed on Form using JSON API or Java Plugin (instead of Drag/Drop or Upload). Any option to upload the PDF in File Upload.
We would like to automate the file upload process. Any java stream can be used to convert PDF and upload to FORM file upload field?
