Add pre-built CSS and JavaScript components to Joget
Hi Team,
Is there any option to use "pre-built CSS and JavaScript components " to Joget Setup. Say added later or consume binary in initial setup at the boot time. So custom CSS can be loaded at startup and used later as required.
Best Regards,
      Hi Anders,
      Thank you for sharing details.  Custom HTML is working fine with CSS from resources.
      To make CSS effective for all elements like label, radio button options etc, do I need to find and customize Joget elements from CSS? or is there any better way to implement it. As Joget use its own element nomenclature for elements.
        Hi, you could add the CSS and JavaScript files as Resources, and include in your Userview headers. So in this case, the CSS and JavaScript would be automatically loaded in each page of the respective UIs.
