I don't think you can have different admins managing designing different apps. In this case you would need to run separate instances of Joget Workflow.
Thank you for your answer,
In my society, several departments may design apps as admins. These apps must not be seen by the other department admins. Is it possible and how ?
Hi there, We can designate a specific user using various options (see http://dev.joget.org/community/display/KBv4/Permission+Control) that access the "management/admin" of each Joget App based on its Userview or Userview Category permission. Can you tell us more about your use case if it differs from above? Thanks. Hugo
Hello
is it possible to specialize one context per admin with the joget entreprise edition ?
each administrator seeing only his own applications ?
