i found that you can use css class ".jqplot-axis.jqplot-xaxis" for x-axis and ".jqplot-axis.jqplot-yaxis" for y-axis to modify the font size
Based on the documentation at SQL Chart, it does not seem like there is a configuration for font size. Don't think CSS will work because the chart is a generated image.
Hi to everyone.
Can you help me to find a way tor changing font sizes in my SQL charts axis? I've tryied with some css script code with no success.
Any advise is very wellcome.
