Post Processing Tool - in child form?
Hi Experts,
any workaround to run Post Processing Tool in child form, after "Submit" button?
Run a tool after a form is submitted. Only applicable for primary form.
BR,
Sylwester
      Usually process tool, is part of the process. If you want to run process tool after submit child form. Means the process have to run after child form is submitted, in order to get to the process tool. Which is not right, because you are still in the middle of filling the parent form.
      If you want to do something (calculate field, integrate with other system) after a child form is submitted, you can use REST to do GET/POST data using JOGET Plugin Web Support.
      Best Regards,
