how do i save my process builder?
hi! i am currently doin my project into my localhost. then when i am done i will export the app and import it into the server, but the process design is not included. how will i save the process builder?
      When you export / import apps all forms, datalists, userviews and processes are included. If the process is not included for some reason you could still copy and paste the xpdl code from the top right corner in the process designer.
        If the process design is not included after import, there must be an exception in the log file. You can refer to it.
