how can i resolve this?
$(document).ready( function(){
$('select[name="picname"]')[0].options.add(new Option('Mary Cyndell Budino','Mary Cyndell Budino'));
$('select[name="emailpic"]')[0].options.add(new Option('cyndell.budino@ph.yusen-logistics.com','cyndell.budino@ph.yusen-logistics.com'));
$('select[name="level"], select[name="purpose"]').change(function(){
if($('select[name="level"]').val() === '1' && $('select[name="purpose"]').val() === 'Business Trip' || $('select[name="purpose"]').val() === 'Training')
$('select[name="picname"]').empty();
$('select[name="emailpic"]').empty();
if($('select[name="level"]').val() === '1' && $('select[name="purpose"]').val() === 'Hand Carry' || $('select[name="purpose"]').val() === 'Training')
$('select[name="picname"]')[0].options.add(new Option('Rose Leron','Rose Leron'));
$('select[name="emailpic"]')[0].options.add(new Option('rose.leron@ph.yusen-logistics.com','rose.leron@ph.yusen-logistics.com'));
if($('select[name="level"]').val() === '2' && $('select[name="purpose"]').val() === 'Business Trip' || $('select[name="purpose"]').val() === 'Training')
$('select[name="picname"]')[0].options.add(new Option('Vida Janda / Errian Katigbak','Vida Janda / Errian Katigbak'));
$('select[name="emailpic"]')[0].options.add(new Option('Executive Assistants','vida.janda@ph.yusen-logistics.com, errian.katigbak@ph.yusen-logistics.com'));
if($('select[name="level"]').val() === '3' && $('select[name="purpose"]').val() === 'Business Trip' || $('select[name="purpose"]').val() === 'Training')
if($('select[name="level"]').val() === '4' && $('select[name="purpose"]').val() === 'Business Trip' || $('select[name="purpose"]').val() === 'Training')
if($('select[name="level"]').val() === '5' && $('select[name="purpose"]').val() === 'Business Trip' || $('select[name="purpose"]').val() === 'Training')
if($('select[name="level"]').val() === '6' && $('select[name="purpose"]').val() === 'Business Trip' || $('select[name="purpose"]').val() === 'Training')
if($('select[name="level"]').val() === '7' && $('select[name="purpose"]').val() === 'Business Trip' || $('select[name="purpose"]').val() === 'Training')
if($('select[name="level"]').val() === '8' && $('select[name="purpose"]').val() === 'Business Trip' || $('select[name="purpose"]').val() === 'Training')
if($('select[name="level"]').val() === '2' && $('select[name="purpose"]').val() === 'Hand Carry')
if($('select[name="level"]').val() === '3' && $('select[name="purpose"]').val() === 'Hand Carry')
if($('select[name="level"]').val() === '4' && $('select[name="purpose"]').val() === 'Hand Carry')
if($('select[name="level"]').val() === '5' && $('select[name="purpose"]').val() === 'Hand Carry')
if($('select[name="level"]').val() === '6' && $('select[name="purpose"]').val() === 'Hand Carry')
if($('select[name="level"]').val() === '7' && $('select[name="purpose"]').val() === 'Hand Carry')
if($('select[name="level"]').val() === '8' && $('select[name="purpose"]').val() === 'Hand Carry')
</script>
thats my javascript code but when i go to the next form and this is a subform, it errors. what is wrong?
  1. Walter
    Hi there, Try not to write so much of custom code in your app. Things will go out of hand very quickly just like what you are experiencing now. I cannot help you too without you providing steps to replicate your issue. You did not even tell us what error your are getting. Best of luck!
    Hi Jedi
    Do show the error message or joget.log snippet of the error.
    Thank you
    1. jedi
      actually the error occurs when i complete the next process. code violatioon is displayed.
    2. Matthew King
      Jedi, first test without the javascript code (cut it out from your Joget form). If the error still occurs, then its not the Javascript problem. If there is no error (without Javascript), try getting help just for the Javascript from http://stackoverflow.com/
