Hi, if you are using the Professional or Enterprise edition and have a support contract, that would be the best place to raise a ticket. Otherwise you could try to create an issue in the GitHub project.
I would like to open a bug for Joget 7.0
Assign user to organization API call actually replaces all the Organizations that the user was assigned to, before. I think this is not correct, it should just add another Organization, assigned to the specific User, like it does using the UI User management.
