Customize userview theme is not working?
I had done little customization in Corporati theme (CSS files) in local host and it is working fine as well on local machine.
However, I have deployed my app on Openshift successfully but my customized theme is not working on it. I've replaced the original 'Corporati' theme files with my customized ones on my Openshift server. It is still appearing the default Corporati theme.
I would appreciate any help in this regard
Best regards
Kamran
  1. panda
    it is not enough details to help u. as u mentioned it is working in ur local machine, then it should work in ur openshift server as well. u may use the browser developer tool to check whether the customized css are loaded or not.
    Download and try out the free Simple Help Desk app in Joget Marketplace that demonstrate the use of CSS in 'Userview>Settings' to beautify and enhance the look and feel of Joget apps.
