There is an error Occurs in my terminal....
When we try to Log in the Portal, we got the error in the terminal, and we not able to use the web portal, how can I rectify it...
WARN 04 Sep 2023 10:31:31 bitronix.tm.BitronixTransaction - transaction timed out: a Bitronix Transaction with GTRID [62746D2D6A6F6765740000000AB27D7B5200000053], status=MARKED_ROLLBACK, 0 resource(s) enlisted (started Wed Jun 16 23:47:20 IST 1971)
      Hi, there is not enough information to help. Try checking the complete error messages and traces in the logs which should describe the actual error causing the transaction to timeout.
