you may have to use Javascript, see an example in How to Disable Collapsible Categories on DX X-Admin Theme
The best is you write your own userview or UI theme plugin, see How to develop a Userview Theme PluginAdd your comment...
With Joget DX7/DX8 and DX Progressive Theme, what is the solution to keep expanded side submenus by default in UI?
