You can't do that! Apparently the runProcess (start task) can't receive incoming transitions.
You could add an activity after your runProcess that would accept incoming transitions.
Add your comment... - 210
Hi, as Ashutosh mentioned, you can't loop back to the starting activity. What you can do is to introduce a dummy route as the starting activity, as per the example process below:
Hi Ernest Pachonick
It would be helpful if you can upload a screenshot of your current workflow and draw in the requirements.
The Joget Marketplace has free sample apps with working process workflows you can view/try out, which might meet your requirements:
- Simple Leave: view the "Leave Application System" workflow
- Approve Via Email: view the "Test Approval Via Email" workflow
Hi , i urgently need an answer to my issue: I need to return my flow, to the start task, after a decision route option has been chosen. however, when i drag the arrow back to the return task, from the route, I get an error saying" No start defined" this kind of functionality is available in other workflow products. does this functionality exist in Joget? we need to make a decision whether or not to purchase Joget, so I need the answer asap please. Thanks!
