Custom Form Permission Plugin did Not Work
Dear Expert,
I am creating a simple permission plugin to disable a section if the user using a Mobile View. by "MobileUtil.isMobileView()"
And I build the Plugin successfully. but it is not able to install it with the joget Console.
here is the Source Code.
Activator.java
package org.joget.tutorial;
import java.util.ArrayList;
import java.util.Collection;
import org.osgi.framework.BundleActivator;
import org.osgi.framework.BundleContext;
import org.osgi.framework.ServiceRegistration;
public class Activator implements BundleActivator {
    protected Collection<ServiceRegistration> registrationList;
    public void start(BundleContext context) {
        registrationList = new ArrayList<ServiceRegistration>();
        //Register plugin here
        registrationList.add(context.registerService(NotMobileView.class.getName(), new NotMobileView(), null));
    public void stop(BundleContext context) {
        for (ServiceRegistration registration : registrationList) {
            registration.unregister();
NotMobileView.java
import org.joget.apps.app.service.AppPluginUtil;
import org.joget.apps.form.model.FormPermission;
import org.joget.apps.userview.model.UserviewPermission;
import org.joget.apps.app.service.MobileUtil;
public class NotMobileView extends UserviewPermission
    implements FormPermission
    public NotMobileView()
    @Override
    public String getName()
        return "Not MobileView";
    @Override
    public String getVersion()
        return "5.0.0";
    @Override
    public String getDescription()
        return AppPluginUtil.getMessage("org.joget.tutorial.NotMobileView.pluginDesc", getClassName(), "messages/NotMobileView");
    @Override
    public String getLabel()
        return AppPluginUtil.getMessage("org.joget.tutorial.NotMobileView.pluginLabel", getClassName(), "messages/NotMobileView");
    @Override
    public String getClassName()
        return getClass().getName();
    @Override
    public String getPropertyOptions()
        return AppUtil.readPluginResource(getClassName(), "/properties/NotMobileView.json", null, true, "messages/NotMobileView");
    @Override
    public boolean isAuthorize()
        boolean isAuthorize;
        isAuthorize = false;
        if (!MobileUtil.isMobileView()) {
        	isAuthorize = true;
        return isAuthorize;
NotMobileView.json
        "title":"@@userview.notmobileview.config@@",
        "properties":[{
        "name":"permission",
        "label":"@@userview.notmobileview.permission@@",
        "type":"elementselect",
        "options_ajax":"[CONTEXT_PATH]/web/property/json/getElements?classname=org.joget.apps.userview.model.UserviewPermission",
        "url":"[CONTEXT_PATH]/web/property/json[APP_PATH]/getPropertyOptions"
NotMobileView.properties
org.joget.tutorial.NotMobileView.pluginLabel=Not MobileView
org.joget.tutorial.NotMobileView.pluginDesc=Return True if not using mobile view
userview.notmobileview.config=Configure Not Mobile View
userview.notmobileview.permission=Permission
and the Jar folder structure is
-org
	-joget
		-tutorial
			*Activator.class
			*NotMobileView.class
-messages
	*NotMobileView.properties
-properties
	*NotMobileView.json
Any Idea what I am doing Wrong ?
Best Regards
Tony Chu
      There did not have any error captured at joget.log
      1. Anders
        Can you elaborate on "but it is not able to install it with the joget Console." with more details?
      What error are you getting? The exception and stacktrace would tell you what is wrong with the code.
