if you really want to add your own custom button. you can use jquery javascript as follow
// Add Save as Draft Button $(document).ready(function(){ var draft= $('<input id="saveAsDraft" name="draft" class="form-button" type="submit" value="#i18n.saveAsDraft#"/>'); draft.insertBefore($('input#submit.form-button')); $('input#saveAsDraft.form-button').on('click',function(event){ event.stopPropagation(); $("input[name='status']").val(0); $('input#submit.form-button').trigger("click"); event.preventDefault(); }); });Add your comment... - 10-1
Hi, you do not need to manually add a button to a form. An appropriate submit button will automatically be displayed in the form when the form is displayed in a userview.
Hi Guy's,
Is there any way to create a submit button on a form?
Thanks,
