How can I create a DB Transaction with Joget BeanShell Script
Dear Expert,
I would like to make a db transaction with the following code.
Connection con = null;
con = ds.getConnection();
try{
	if (!con.isClosed()){
		con.setAutoCommit(false);
		// Some code to select a Record for checking!
		// sql = "select * from tables for update";
		if (checking == true) {
			result = true;
		} else {
			// Some code update another db record here!
		con.commit();
} catch (Exception e) {
	LogUtil.error("Application",e, "Error updateing data");
} finally {
	if (con !=null) {
		con.close();
However, I get the error of  "java.sql.SQLException: Auto-commit can not be set while enrolled in a transaction"
Everyone can point me how to solve this problem.
Many Thanks!
Best Regards
Tony Chu
      Ok I found out  the answer and here is the Code by using:
      con.setTransactionIsolation(Connection.TRANSACTION_READ_COMMITTED);
      and not
      try{
                  result = true;
              } else {
              con.close();
      } finally {
          if (con !=null) {
              con.close();
