In your Tool, map to Beanshell plugin. Then use the code from Setting Workflow Variable Value in Process Tool Bean Shell
Hi Guy's,
Hope you can help.
I need to populate a workflow variable from a database return value.
I am using an "tool" step to do this.
What is the best way of achieving this?
Thanks,
Ernest.
