You must use JDK or JRE in order to run Tomcat (your app server) so that Tomcat can then host Joget Workflow.
You will also need Oracle JDBC driver if you are connecting Joget Workflow to Oracle database system.
Cheers
- shaker alzoubi
Why such requirments, is not listed as prerequist to Joget installtion on Windows enviorment.
- Walter
It is already bundled in therefore you don't need to first install them.
- shaker alzoubi
But it does not work.
Should the Oracle JDBC and Java JRE/ JDK being installed. before starting the Joget Enterprise edition.
on windows server 2012 R2?
