Is works when put the following only
Admin Role Import Search Filter:::
(|(sAMAccountName=admin1)(sAMAccountName=admin2))
Hello, it looks correct but it depends on your Active Directory structure. You can turn on the Debug Mode in the LDAP Directory Manager configuration and it will display the queries in the logs to help you tune your configuration.
I used the stiring:
in the filter admin role:
(&(objectClass=person)(|(cn=padmin1)(cn=padmin2)))
only padmin1 is working wel,, since it the primary admin on first page setup.
and it was set while using the string:
(cn=padmin1)
