Hello, I do not really understand what you mean by "overcome Active directory users authentication". Assuming that you wish to not use AD authentication, you should disable the LDAP Directory Manager. Or you could change the mapping of the participants when testing.
- shaker alzoubi
what Iemans, is to run the tested application without requiring users credintials, while logging. How to map or overrite that arribute, that requiers login.
While testing workflow, in simulation mode, how to overcome Active directory users authentication?
To enuure that each users in each step is reciving the actions to d as designed.
