Rich Text Format in Download PDF Plugin
Download PDF plugin is used to download a form content into PDF. Everything works fine, except the Rich Text field appears as a plain text in the PDF. Is there anyway to fix this?
      Hi, I assume you mean the Download PDF plugin in the marketplace? It seems the source code is available in How to develop a Download PDF Datalist Action so you might want to check it out there.
