Hi, why don't you just store the value as a normal form field? You could try writing some custom script to store it in the HTTP session, but it would be much easier to just store it as a form value.
I have to form to select the division code.
I want to use this selected value in all the other forms/datalists till we logout or close the application.
Is there a variable which I can set and use like global variable.
