Hi Cee,
The Starter and Standard On-Demand plans are shared hosting, so due to security considerations they do not allow remote database connections or database connections to external datasources.
If you have such requirements then you would need to either use the Dedicated plan or deploy an on-premise installation.
Best Regards
JulianAdd your comment...
Hello,
i try to connect to a google cloud sql mysql database (version 1).
Access from all IP's is whitelisted, user account has global privilieges (tested with other app, works).
But when trying to use it in jdbc binder, i always get
my JDBC connect line is
jdbc:mysql://XXX.XXX.XXX.XXX:3306/YYYYY
interesting is: when i dont use the correct database name as YYYYY, but a wrong one,
i do get the message:
So it looks like it actually can connect...
Any hints?
Thank you!
Cee Bee
