Hi, there is a related question Integration with Oracle 12c || tables not auto created. Did you try using the Enterprise Edition? I am using it with Oracle and it is working fine.
I create a jar File With It Class And Insert Into Lib of jw project, And Edit hibernate.cfg.xml and insert Line of hibernate.dialect with value OracleCustomeDialect...
And... Start Project...
And Bug Fix...
Tank You...
How to Override Oracle10gDialect In Joget Source Or Use OracleCustomDialect?
In which class should be?
I takeThis Error...
Hibernate: create table app_fd_travel_requests (id varchar2(255 char) not null, dateCreated timestamp, dateModified timestamp, c_data_form long, c_remark long, c_name long, c_approval long, c_data_to long, primary key (id)) INFO 20 Apr 2017 03:56:04 java.sql.DatabaseMetaData - HHH000262: Table not found: app_fd_travel_requests INFO 20 Apr 2017 03:56:04 java.sql.DatabaseMetaData - HHH000262: Table not found: app_fd_travel_requests INFO 20 Apr 2017 03:56:04 java.sql.DatabaseMetaData - HHH000262: Table not found: app_fd_travel_requests Hibernate: select count(*) as col_0_0_ from app_fd_travel_requests app_fd_tra0_ ERROR 20 Apr 2017 03:56:04 org.hibernate.engine.jdbc.spi.SqlExceptionHelper - ORA-00942: table or view does not exist ERROR 20 Apr 2017 03:56:05 org.joget.apps.datalist.model.DataList - Error retrieving binder row count org.hibernate.exception.SQLGrammarException: could not extract ResultSet at org.hibernate.exception.internal.SQLExceptionTypeDelegate.convert(SQLExceptionTypeDelegate.java:80) at org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:49) at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:126) at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:112) at org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.extract(ResultSetReturnImpl.java:91) at org.hibernate.loader.Loader.getResultSet(Loader.java:2066) at org.hibernate.loader.Loader.executeQueryStatement(Loader.java:1863) at org.hibernate.loader.Loader.executeQueryStatement(Loader.java:1839) at org.hibernate.loader.hql.QueryLoader.iterate(QueryLoader.java:520) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.iterate(QueryTranslatorImpl.java:428) at org.hibernate.engine.query.spi.HQLQueryPlan.performIterate(HQLQueryPlan.java:322) at org.hibernate.internal.SessionImpl.iterate(SessionImpl.java:1365) at org.hibernate.internal.QueryImpl.iterate(QueryImpl.java:70) at org.joget.apps.form.dao.FormDataDaoImpl.internalCount(FormDataDaoImpl.java:372) at org.joget.apps.form.dao.FormDataDaoImpl.count(FormDataDaoImpl.java:331) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157) at org.joget.apps.app.service.AuditTrailInterceptor.invoke(AuditTrailInterceptor.java:17) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:99) at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:281) at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:96) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:92) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:207) at com.sun.proxy.$Proxy27.count(Unknown Source) at org.joget.apps.datalist.lib.FormRowDataListBinder.getDataTotalRowCount(FormRowDataListBinder.java:152) at org.joget.apps.datalist.model.DataList.getTotal(DataList.java:460) at org.joget.apps.datalist.model.DataList.getRows(DataList.java:416) at org.joget.apps.datalist.model.DataList.getRows(DataList.java:407) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at javax.el.BeanELResolver.getValue(BeanELResolver.java:97) at org.apache.jasper.el.JasperELResolver.getValue(JasperELResolver.java:110) at org.apache.el.parser.AstValue.getValue(AstValue.java:167) at org.apache.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:184) at org.apache.jasper.el.JspValueExpression.getValue(JspValueExpression.java:115) at org.apache.jsp.WEB_002dINF.jsp.dbuilder.dataListView_jsp._jspx_meth_c_005fset_005f8(dataListView_jsp.java:1235) at org.apache.jsp.WEB_002dINF.jsp.dbuilder.dataListView_jsp._jspx_meth_c_005fcatch_005f1(dataListView_jsp.java:1199) at org.apache.jsp.WEB_002dINF.jsp.dbuilder.dataListView_jsp._jspService(dataListView_jsp.java:290) at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70) at javax.servlet.http.HttpServlet.service(HttpServlet.java:725) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:431) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:396) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:340) at javax.servlet.http.HttpServlet.service(HttpServlet.java:725) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:721) at org.apache.catalina.core.ApplicationDispatcher.doInclude(ApplicationDispatcher.java:584) at org.apache.catalina.core.ApplicationDispatcher.include(ApplicationDispatcher.java:523) at org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRuntimeLibrary.java:934) at org.apache.jsp.WEB_002dINF.jsp.userview.plugin.datalist_jsp._jspx_meth_c_005fif_005f3(datalist_jsp.java:364) at org.apache.jsp.WEB_002dINF.jsp.userview.plugin.datalist_jsp._jspService(datalist_jsp.java:161) at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70) at javax.servlet.http.HttpServlet.service(HttpServlet.java:725) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:431) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:396) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:340) at javax.servlet.http.HttpServlet.service(HttpServlet.java:725) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:721) at org.apache.catalina.core.ApplicationDispatcher.doInclude(ApplicationDispatcher.java:584) at org.apache.catalina.core.ApplicationDispatcher.include(ApplicationDispatcher.java:523) at org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRuntimeLibrary.java:934) at org.apache.jsp.WEB_002dINF.jsp.ubuilder.view_jsp._jspx_meth_c_005fwhen_005f6(view_jsp.java:1986) at org.apache.jsp.WEB_002dINF.jsp.ubuilder.view_jsp._jspx_meth_c_005fchoose_005f5(view_jsp.java:1948) at org.apache.jsp.WEB_002dINF.jsp.ubuilder.view_jsp._jspService(view_jsp.java:552) at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70) at javax.servlet.http.HttpServlet.service(HttpServlet.java:725) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:431) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:396) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:340) at javax.servlet.http.HttpServlet.service(HttpServlet.java:725) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:721) at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:466) at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:391) at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:318) at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:168) at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:303) at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1244) at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1027) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:971) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:966) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:857) at javax.servlet.http.HttpServlet.service(HttpServlet.java:618) at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:842) at javax.servlet.http.HttpServlet.service(HttpServlet.java:725) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.displaytag.filter.ResponseOverrideFilter.doFilter(ResponseOverrideFilter.java:125) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.owasp.csrfguard.CsrfGuardFilter.doFilter(CsrfGuardFilter.java:88) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:122) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:48) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205) at org.joget.apps.workflow.security.WorkflowHttpAuthProcessingFilter.doFilter(WorkflowHttpAuthProcessingFilter.java:84) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:120) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:64) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:53) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213) at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:344) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:261) at org.joget.commons.spring.web.CustomDelegatingFilterProxy.doFilter(CustomDelegatingFilterProxy.java:30) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.joget.apps.app.web.ExpireFilter.doFilter(ExpireFilter.java:43) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:85) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:516) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1086) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:659) at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:223) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1558) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1515) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Unknown Source) Caused by: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:450) at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:399) at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1059) at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:522) at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:257) at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:587) at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:225) at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:53) at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:774) at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:925) at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1111) at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:4798) at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:4845) at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1501) at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96) at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96) at org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.extract(ResultSetReturnImpl.java:82) ... 169 moreBecause, Oracle can not create a table with Long values, And I Create This Table Manually And Replace Long Datatype With Clob And All Things Was OK, But I will This Problem Automatically... Who's The Solution?
Help Me, Plz..
