Workflow variable encryption
Hi team,
Is it possible to encrypt / decrypt a workflow variable?
I tried to find information on this but couldn't see anything written about it.
Since v6 encryption seems to have been added to some form fields but what about workflow variable encryption / decryption - are there any plans or ways of implementing this?
Cheers,
Eric
  1. Walter
    In my opinion, we should reserve it for routing purpose. Can you share with us what is your use case here? TQ!
  2. Eric
    Hi Walter, I use it to handle more or less temporary auth tokens. I guess they could be stored to a form field by the json tool for example but even then the value would not be encrypted, correct?
    Hi, I don't see any encryption option in workflow variables, but you could always perform your own encryption using some BeanShell or plugin code?
    1. Eric
      I guess I could but the performance wouldn't be great I think - might try it out.
