Hi, yes there are various ways for integration as described in the Integration page eg you can use the JSON API. There is also an example at Start a Process from External Page.
I have a requirement of integrating Joget with external application.
Is there any possible ways to trigger a Joget process from external application and send back the workflow/form variable to the external application as response.
