Is there a way to get all app ids that the current user has?
I need to retrieve the app IDs that the user has so I can use them to get the necessary processes of the app IDs on a later field. Is there a way to do this?
      Thank you for the answers, I have figured it out. I realized it is much simpler than I thought. I can get the app list from the apps table itself in the database.
        I would suggest creating a datalist to get all the APP IDs.
        And then use datalist hashvariable ( #datalist.col.csv.ID.column# ) to get all the records. You can apply filter to the variable as well.
        Please read here : Hash Variable#DatalistHashVariable
              AppDefinitionDao appDefinitionDao = (AppDefinitionDao)AppUtil.getApplicationContext().getBean("appDefinitionDao");
              appDefinitionList = appDefinitionDao.findPublishedApps("name", Boolean.FALSE, null, null);
              for (Iterator i = appDefinitionList.iterator(); i.hasNext();) {
                 AppDefinition appDef = i.next();
                 //this will give you the app
