Hi Noor Juaini Zakaria
You can re-download and re-import a brand new copy of the Leave App from Joget Marketplace into your localhost Joget Workflow.
The newly imported Leave app will automatically be the next version number, i.e. Version 2. To change to the new version, click on the green Published button and make the selection in the pop-up window.
You can then re-open the Leave Apply form, extract or copy what you need and switch back to your original version and paste the code
Hi Andrew,
Thank you for the solution. It really help me..
Hi, can anyone share me the bean shell binder script for leave type field in apply leave form of leave application system in joget? i mistakenly deleted the binder and lost the script. thank you.
it is the default script in leave application system
