BeanShell Validator for Checkbox
Hi Experts,
I´m needing  validate the value in a checkbox located in a spreadsheet, anybody have an example about the code lines to do it?
I'm using this code currectly but it don't work,  I'm remark the lines specifically with the problem.
I have tried saving the value in an String and later in an Boolean variable but I don't achieve do the evaluation.
public boolean validate(Element element, FormRowSet rows, FormData formData) {
    boolean result = true;
    if (rows != null && !rows.isEmpty()) {
        int total = 0;
        String haycancelacion = "No";
        //Sum the values from column "amount"
        for (FormRow row : rows) {
            try {
                int can_registrada = Integer.parseInt(row.getProperty("can_movimiento"));
                int can_pedida = Integer.parseInt(row.getProperty("cantidad"));
                int can_aprovisionada = Integer.parseInt(row.getProperty("cant_aprov"));
                total += can_registrada;
                var isChecked = row.getProperty("cancelar");  //Remark "This is the field Type Checkbox in the spreadsheet .
                cantidad_maxima = (can_pedida - can_aprovisionada);
                    if (can_registrada > cantidad_maxima) {
                        String id = FormUtil.getElementParameterName(element);
                        formData.addFormError(id, "La cantidad aprovisionada no puede ser mayor a la cantidad solicitada menos la cantidad aprovisionada!!!! ");
                        result = false;
                    else {
 //This is the first evaluation that I'm trying to do and don't work, the evaluation is bypassed (of course does not by the value of can_aprovisionada)
                    if (can_aprovisionada > 0 && isChecked == true) {
                        formData.addFormError(id, "No puede cancelar un requerimiento previamente aprovisionado!!!! ");
                        result = false;
//This is the second evaluation that I'm trying to do and don't work, the evaluation is bypassed (of course does not by the value of can_registrada)
                     else if (can_registrada == 0 && isChecked == true){
                        haycancelacion = "Si";
                } catch (Exception e) { LogUtil.error("Sample app - Bulk Create Users form", e, "Store user error!!"); }
        if (total == 0 && haycancelacion.equals("No")) {
            formData.addFormError(id, "Aprovisione alguno de los artículos antes de continuar!!!!" + isChecked);
            result = false;
    return result;
//call validate method with injected variable
return validate(element, rows, formData);
      System.out.println("isChecked: " + isChecked);
      How about you try placing the line above right after var isChecked = row.getProperty("cancelar"); to see if the checkbox state is correctly obtained.
      Now, for the conditions not behaving as expected:
      1. can_aprovisionada > 0 && isChecked == true: Verify that can_aprovisionada is greater than 0 when you expect it to be and isChecked is true when the checkbox is checked. You might also print out can_aprovisionada and isChecked to ensure they have the expected values.
      2. can_registrada == 0 && isChecked == true: Similar to above, ensure that can_registrada is indeed 0 when expected and isChecked reflects the checkbox state.
      Let me know how it goes.
      1. Fabian Barrera
        Hi John Smith   finally I found the way to manage this type of values, this is the piece of code:
        Thanks for Your Ilustration, I would like to ask you where I can see teh output fo this
        instruccion System.out.println("isChecked for this row: " + isChecked);  if I'm working on cloud version
        boolean isChecked = false;
          try {
            // ... your existing code ...
            // Get the value of the "cancelar" checkbox
            isChecked = Boolean.parseBoolean(row.getProperty("cancelar"));
          } catch (Exception e) {}
