Might as well you have to check the configuration of the jdbc binder .
Whether it is being set individually on each form or on the main parent form itself.
It is best for you to test each configuration scenarios and see the behaviour after you configure it at :
1 ) Main Parent Form
2) Individual Configuration on each form in the multipage.
Let me know how it goes!Add your comment...
i alredy try using this for fix issue on multi page when set read only but the problem still the same .
maybe because me using jdbc binder custom datasource . is possible to fixed it on jdbc custom datasource ?
