Forcing a calculation field when result is less than real operation
I there experts. In the calculated field i am multiplying a *  b. But i want  when the result of the operation is less then a given number (for exemple less than 2, the value that is showned is 100. For example, if a * b is 2, the value of the calculated field should be 100, instead of real result (2). Resuming, the user should see 100, when the result of the operation is less than 2.
is there any easy way to do this without  code?
      hi,
      the arithmetic operator in the calculation field Operation field cannot handle the conditional logic
      This is the low code way.
      Just simply have a custom html and apply this javascript to have the conditional formatting to work.
      <script>
          // Function to perform calculation and apply conditional logic
          function calculateAndFormat() {
              var a = parseFloat(document.getElementById("a").value);
              var b = parseFloat(document.getElementById("b").value);
              var result = a * b;
              if (result <= 2) // Adjust here according to the value you wanted to control
                  result = 100;
              document.getElementById("result").value = result;
          // Event listeners to trigger calculation when input changes
          document.getElementById("a").addEventListener("input", calculateAndFormat);
          document.getElementById("b").addEventListener("input", calculateAndFormat);
      </script>
      Sample app for you too : APP_calculateField-1-20240712143933.jwa
      1. Ulisses
        Hi there, had no ideia that this could be done. Thank for your time and for the example app, it will solve my problem. Regards.
      make calculation field hidden. use section visibility conditions
      Section - Knowledge Base for DX 8 - Joget | COMMUNITY
      assuming you're using the latest joget dx 8 version check the value of the calculation field
      if its 2 or below, show this section with a label/field that says 100 (hardcoded maybe?)
      then another section that will be visible based on the visibility  condition of 2 or more to show whatever you need to show
      1. Ulisses
        Thank you for the suggestion, but its not a visibility issue.
