I have found it. When you have a blank report without bind to a query then the query tag is empty. You have to put a simple fake query (with a table from the joget database and not an undefined table)!!!
have you tested the sample app here in this KB ?:
JasperReports Menu#DownloadDemoApp
Have a go with this app and see whether it works or not.
I am not sure on the Jasper Version that Joget is using.
However,
It works on my end using Joget Cloud Version 8.1.2Add your comment...
Hello. I have downloaded jasper studio community edition 7. I made a simple blank A4 report without records (not using a database) only with a "TEST" title just for the proof of concept. I took the jrxml and placed it in the joget "Jasper Reports Definition". When I try to preview it then it throws an error: "org.xml.sax.SAXParseException; lineNumber: 2; columnNumber: 208; cvc-complex-type.3.2.2: Attribute 'uuid' is not allowed to appear in element 'jasperReport'."
The jrxml is:
I think that is a compatibility issue. Maybe the rendering jasper report engine that joget uses is older than jasper 7 edition. Should I download an older version of jasper studio?
