giving parameters other than id in hyperlinks
is it possible to give any other parameters lets say like username in parameters other than id in hyperlinks.
its because i want to have a common value for a entity between all the tables but id changes for each table
      Not sure where exactly this is. but for example in datalist hyperlink action, you can set the parameter name
      Hyperlink Action - Knowledge Base for DX 8 - Joget | COMMUNITY
      and you can consider using Request Parameter Hash Variable to call that parameter nameĀ Hash Variable - Knowledge Base for DX 8 - Joget | COMMUNITY
