how to add new row in form grid using javascript (will trigger by a button) ?
I have created a button to auto-generate the number of rows predefined by user into form grid.  I do checked there's a sample script - Add a new Row in Form Grid using script from Knowledge Base, anyhow I am not sure how to call it from my button, is it using onClick event?
Would appreciate your advise.  Many thanks ahead.
Regards,
Wah Man
      Hi, based on the sample script, it think you first need to make it a function first as following, how to trigger this function is based on how and when you want the function is call.
      function addRow() {
          // the field id is "entries"
          var field = FormUtil.getField("entries");
          var functionName = window[field.attr("id") + "_add"];
          if(typeof functionName === 'function') {
              var args = new Object();
              args['result'] = '{"amount":"1","category":"Medical","claim":"","purpose":"a","date":"11/18/2015","formattedAmount":"$ 1.00"}';
              functionName(args);
